Fiixing squeaky sub-floors
   / Fiixing squeaky sub-floors #11
Thanks for the help. I already have 2 and 2.5 inch deck screws (star drive) and will try the glue/caulk approach. I may go the Squeek-no-more route to get a head start, since radioman cautions about how much time I may (not) have when the carpet guys are here.
If you're like me when it comes to squeaky floors/stairs it will be worth the wait (and expense) to have them "tear it up and come back tomorrow" so you can do it right.
   / Fiixing squeaky sub-floors #12
.... get out a measuring tape and a piece of paper and some painter's tape .....
walk the room ( area) and note where the squeaks are , put a tab of tape over the general spot on the carpet ....
keep going till you've marked all of of them... ( note positions on the paper after measuring from walls )
re-walk again to make double sure ...
then cut out a square of carpet around a marked area ... find the floor joints and mark them ... sink at least 3 to 4 deck screws ( 2 inches apart ) in the area INTO the marked joist... re-walk the area and see if the noise is gone ... most noise is from a loose board wiggling over a joist ( like a teeter totter )
repeat with the other marked areas ....
You've convinced me that I need to do this now, before the carpet arrives. I don't think there will be any slack time available. Thanks.
Okay, just finished up and glad I took your advice! It took longer than anticipated and I would never have gotten this done with the installers waiting. I cut the carpet, used deck screws, and then taped back over the cut with frog tape. No more squeaks (except my aching back).
I did try the Squeeek-no-more product in one place as a test and it worked as advertised. I'd be willing to use it again on the new carpet if a new squeak develops in the future.
Thanks again for your ideas.
   / Fiixing squeaky sub-floors #15
Glad to hear it worked out. :thumbsup:
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
1264 (A50490)
1264 (A50490)
