crashz
Elite Member
This is not tractor related, but close. This referes to my 1 ton dump truck.
My truck was used to plow and salt roads and parking lots for many years. The body has been completely replaced about two years ago, and while it is starting to corrode a little, its not too bad. The frame and suspension of the truck is very corroded though. When I bought the truck this past May, I inspected it closely and found only one weak spot in the frame. I had that fixed by a certified welder, and all is good. My quest now is to remove as much rust as possible, seal and paint the frame, and possibly prevent any further corrosion using dissimilar metals.
Zinc blocks have been used in marine environments from ship hulls to steel peirs and also in the natural gas industry along steel pipelines. I'd like to use this technology to protect the frame of my truck from any further corrosion with small replacable blocks of zinc bolted directly to the frame. Somewhere in my chemistry notes, I have the calculations for influence area affected by sacrificial metals, so I'll be able to figure out spacing and sizing.
I can't seem to find a source for the zinc though. Has anyone done something like this before? Where do I find the materials? And does anyone have a better method of rust prevention?
