fiat f110 hydraulic coupler diffrent sizes?
   / fiat f110 hydraulic coupler diffrent sizes? #1
fine74955
sallisaw,ok
fiat f110
I am not able to connect anything to the top half of the valve sets the manual states "each control valve is provided with two quick-disconnect push-pull 1/2 in female couplings suitable for connection to pressure connect push-pull male couplings (optional)."
the manual leads me to belive they are both identical so why will my connectors only fit the bottom half of the set?
   / fiat f110 hydraulic coupler diffrent sizes? #2
Maybe they will fit, but the residual pressure prevents you from coupling.
On the tractor side, wiggle the valve lever to release any pressure. On the implement side bleed the QD.
i checked them again i was able to get one set to work i think it just has three bad couplers on it the one of the many joys of second hand tractors as they all appear to be the same size and type
thank you
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
202476 (A54757)
202476 (A54757)
New/Unused CFG Industrial QK18R Mini Excavator (A54865)
New/Unused CFG...
More info coming soon! (A55787)
More info coming...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
