Fiat 80-90 FWD Lower linkage seal's
   / Fiat 80-90 FWD Lower linkage seal's #1
froger111
Fiat 80-90 4x4
G'day all
Have a Fiat 80-90 fwd as in title .. I find it hard to find info on this tractor , can find plenty of part's but not so much on how to install them , I also have a repair pdf manual but still not a lot of good as some part's look like a pencil drawing as it's black and white and bugger all definition and can't find on this part on it anyway ..
At the moment I'm trying to change the lower arm linkage seal's which is a sensor shaft as one was leaking , have taken the appropriate part off that hold's the shaft and removed seal's and outer bushes ..
Now! I need to install the new seal's which are not the same as the seal's that I removed but are correct for this tractor as well also ? I'm hoping that there maybe 80-90 owner's on here or owner's that have a similar set up on their tractor that have performed this task and enlighten me with your knowledge as to which way these new seal's are installed or should I get a set like removed , not really keen on buying a new set as it cost me near $100 so don't want to stuff them , i'm not even sure which way there even supposed to face :)
Any help great ..
Cheers Fred
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
JOHN DEERE Q 850 M LOT NUMBER 226 (A53084)
JOHN DEERE Q 850 M...
