Few questions about JD 5310
   / Few questions about JD 5310 #1
drw
Bronze Member
Jacksonville, TX
Kubota L2800
A neighbor is offering to sell me a JD 5310 tractor (55hp, 2WD) with a 520 loader. He's also including a box blade with the deal. Additionally, the loader has both the bucket and a hay spear that you can change out with.
The tractor only has around 200 hours and has been used only to carry around bales of hay. I haven't looked at it yet but he says it looks like a brand new tractor. The tires still look brand new.
He's offering it for $20,000. Do ya'll think that's a good deal?
My other question is: will this tractor fit my category I implements? Will it fit both Cat I and Cat II implements? Specifically, I want it for doing hay baling, so I need it to work with my 3 point hookup NH 451 sickle mower.
   / Few questions about JD 5310 #3
It will run your sickle bar, you may have to use bushings to get to Cat 1 size. Sounds like practically a new tractor. I had to replace the fuel lines on our 5420 which now has about 470 hours. If the tractor is clean, it should be worth about that much. I prefer the MFWD for loader work.
Kubota RTV500 (A47384)
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2007 International 4300 Dump Truck (A51692)
2007 International...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
