Few Jinma parts for 22 to 40 hp tractors
   / Few Jinma parts for 22 to 40 hp tractors #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
We bought out the complete inventory of a dealer that went under at a good price. In the parts line, we did get some new alternators,starters,water pumps and other misc parts for the tractors coming out of the Jinma factory--The dealer said the parts were for the 22-24--28 and 40 hp models--This is a one shot deal and prices are 1/2 of new and sold on a first come first serve basis--Email sweet@scrtc.com if you have any such needs--I dont have any Jinma parts manuals--so you will need to give me your part# or any info on the parts you may need so we can get the right matchup--Ken Sweet
Sweet Farm Equipment LLC *Over 1000 New and Refurbished Used Implements in stock*
   / Few Jinma parts for 22 to 40 hp tractors #2
Hi KEN:
sounds good I'll have to look at my inventory and see what I need.
some items I do need is ZL20 control valve for my loader, mine leaks down very fast, I'm sure I can rebuild it, but I also want to build a grapple on the bucket and need an extra movement or two, and I can fab up longer bolts no problem.
i'll look at it for part #'s
Mark M /forums/images/graemlins/smile.gif
I will also get some of the specific part numbers and post them later this week--Only engine parts--Thanks--ken
Here is the best up to date list of what I have left--The part #'s and such are hard to read on some items--so I am describing as best I can--Will take $450 for entire 31 piece lot or price 1 piece at a time (Lot higher that way)--Ken Sweet
Sweet Farm Equipment LLC *New First Choice 5 ft sickle bar mowers for small tractors*
JINMA PARTS LIST AS OF 5-15-04
HERE IS WHAT IS IN STOCK TODAY
31 LOTS OF NEW PARTS--I CANT READ ALL THE PART NUMBERS AND ALL THAT I CAN READ,
I HAVE PROVIDED--ALL ARE SOLD AS-IS WITH NO WARRANTY OR GUARANTEE TO FIT AND
ARE PRICED ACCORDINGLY --- $450 FOR ALL + SHIPPING--WILL PRICE INDIVIDUAL ITEMS-
-HOWEVER-PRICING WILL BE HIGHER PER ITEM
CONTACT--- SWEET FARM EQUIPMENT LLC (ASK FOR KEN)
1815 DEFRIES RD
CANMER, KY 42722
PHONE 270-528-3323-MON-FRI-8-5-CST--FAX 270-528-3333
EMAIL sweet@scrtc.com
1--INJECTOR MARKED P-662-00MX TO FIT 243 TRACTOR
2--INJECTOR MARKED P21-1???? TO FIT 322 TRACTOR
3--WATER PUMP WITH CASTING MARKINGS OF CIXI PART # 100-42006-1
4--WATER PUMP FOR 243
5--WATER PUMP MARKED FOR 40 HP MODEL 403 TRACTOR
6--WATER PUMP FOR 220 OR 280???
7--CLUTCH PLATE 8 INCHES DIAMETER 10 MM THICK WITH 20 MM ID AND 12 SPLINES
WITH PART #TV518-21-017
8--CLUTCH PLATE 8 INCHES DIAMETER 10 MM THICK WITH 35 MM CENTER AND 16 SPLINES
9--ALTERNATOR MARKED JF121--200W-14V WITH 3 TERMINALS ON BACK
10-ALTERNATOR MARKED 2JF200--200W-14V
11-ALTERNATOR MARKED JF131--350W-14V
12-ALTERNATOR (LESS PULLY) MARKED 2JF200--200W-14V WITH 3 TERMINALS ON BACK
13-THERMOSTAT MARKED 76 DEGRES C AND 995 ATC ON HOUSING
14-THERMOSTAT 54 MM DIAMETER USA FOR 243
15-4 SEALS 62X42X10
16-1 SEAL 55X35X10
17-MISC 12 PIECE O RING KIT MARKED CBTE310/06HL06 FOR 344 ENGINES ??
18-6207 BEARING 72X35X17
19-MISC 5 PIECE SEAL KIT MARKED HLCBDO6HL06 ??
20-BEARING 55X30X13
21-5 PIECE SEAL KIT MARKED CBNE 300
22-9 MISC OIL FILTERS FOR 243 AND 222 TRACTORS
23-INJECTOR FOR 403 40 HP PART #PF68819
24-INJECTOR FOR 222 22 HP PART #TS4100-19-001
25-MISC FUEL FILTER CAST BRACKET THAT BOLTS TO ENGINE SIDE (WITH FILTER)
26-2 MISC MANIFOLD PREHEATER ELEMENTS
27-THERMOSTAT MARKED 11-5-155 GA---70 DEGREES C
28-STARTER WITH SOLONOID MARKED QDD100C3 ??-2KW-12VOLT WITH 2 MOUNTING HOLES
112 MM ON CENTER AND OVERALL LENGTH IS 11 1/2 INCHES AND 3 7/8 INCH DIAMETER
29-STARTER WITH SOLONOID MARKED QD1328CL??-12VOLT WITH 2 MOUNTING HOLES
120 MM ON CENTER AND OVERALL LENGTH IS 12 1/2 INCHES AND 4 1/2 INCH DIAMETER
30-STARTER AND SOLONOID MARKED QD1308 --12VOLT-3KW
31-1 SLIDE GEAR SET FOR A 222 THAT IS USED TO ENGAGE THE PTO--130 MM DIAMETER 51 TEETH
WITH ANOTHER SPLINED SLIDE GAER IN THE CENTER WITH 16 TEETH
   / Few Jinma parts for 22 to 40 hp tractors #5
72in Rotary Brush Cutter Skid Steer Attachment (A51691)
72in Rotary Brush...
1964 Mercedes (A51694)
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2012 Subaru Legacy Sedan (A51694)
2012 Subaru Legacy...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
