Few Jinma parts for 22 to 40 hp tractors
   / Few Jinma parts for 22 to 40 hp tractors #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
We bought out the complete inventory of a dealer that went under at a good price. In the parts line, we did get some new alternators,starters,water pumps and other misc parts for the tractors coming out of the Jinma factory--The dealer said the parts were for the 22-24--28 and 40 hp models--This is a one shot deal and prices are 1/2 of new and sold on a first come first serve basis--Email sweet@scrtc.com if you have any such needs--I dont have any Jinma parts manuals--so you will need to give me your part# or any info on the parts you may need so we can get the right matchup--Ken Sweet
Sweet Farm Equipment LLC *Over 1000 New and Refurbished Used Implements in stock*
   / Few Jinma parts for 22 to 40 hp tractors #2
Hi KEN:
sounds good I'll have to look at my inventory and see what I need.
some items I do need is ZL20 control valve for my loader, mine leaks down very fast, I'm sure I can rebuild it, but I also want to build a grapple on the bucket and need an extra movement or two, and I can fab up longer bolts no problem.
i'll look at it for part #'s
Mark M /forums/images/graemlins/smile.gif
I will also get some of the specific part numbers and post them later this week--Only engine parts--Thanks--ken
Here is the best up to date list of what I have left--The part #'s and such are hard to read on some items--so I am describing as best I can--Will take $450 for entire 31 piece lot or price 1 piece at a time (Lot higher that way)--Ken Sweet
Sweet Farm Equipment LLC *New First Choice 5 ft sickle bar mowers for small tractors*
JINMA PARTS LIST AS OF 5-15-04
HERE IS WHAT IS IN STOCK TODAY
31 LOTS OF NEW PARTS--I CANT READ ALL THE PART NUMBERS AND ALL THAT I CAN READ,
I HAVE PROVIDED--ALL ARE SOLD AS-IS WITH NO WARRANTY OR GUARANTEE TO FIT AND
ARE PRICED ACCORDINGLY --- $450 FOR ALL + SHIPPING--WILL PRICE INDIVIDUAL ITEMS-
-HOWEVER-PRICING WILL BE HIGHER PER ITEM
CONTACT--- SWEET FARM EQUIPMENT LLC (ASK FOR KEN)
1815 DEFRIES RD
CANMER, KY 42722
PHONE 270-528-3323-MON-FRI-8-5-CST--FAX 270-528-3333
EMAIL sweet@scrtc.com
1--INJECTOR MARKED P-662-00MX TO FIT 243 TRACTOR
2--INJECTOR MARKED P21-1???? TO FIT 322 TRACTOR
3--WATER PUMP WITH CASTING MARKINGS OF CIXI PART # 100-42006-1
4--WATER PUMP FOR 243
5--WATER PUMP MARKED FOR 40 HP MODEL 403 TRACTOR
6--WATER PUMP FOR 220 OR 280???
7--CLUTCH PLATE 8 INCHES DIAMETER 10 MM THICK WITH 20 MM ID AND 12 SPLINES
WITH PART #TV518-21-017
8--CLUTCH PLATE 8 INCHES DIAMETER 10 MM THICK WITH 35 MM CENTER AND 16 SPLINES
9--ALTERNATOR MARKED JF121--200W-14V WITH 3 TERMINALS ON BACK
10-ALTERNATOR MARKED 2JF200--200W-14V
11-ALTERNATOR MARKED JF131--350W-14V
12-ALTERNATOR (LESS PULLY) MARKED 2JF200--200W-14V WITH 3 TERMINALS ON BACK
13-THERMOSTAT MARKED 76 DEGRES C AND 995 ATC ON HOUSING
14-THERMOSTAT 54 MM DIAMETER USA FOR 243
15-4 SEALS 62X42X10
16-1 SEAL 55X35X10
17-MISC 12 PIECE O RING KIT MARKED CBTE310/06HL06 FOR 344 ENGINES ??
18-6207 BEARING 72X35X17
19-MISC 5 PIECE SEAL KIT MARKED HLCBDO6HL06 ??
20-BEARING 55X30X13
21-5 PIECE SEAL KIT MARKED CBNE 300
22-9 MISC OIL FILTERS FOR 243 AND 222 TRACTORS
23-INJECTOR FOR 403 40 HP PART #PF68819
24-INJECTOR FOR 222 22 HP PART #TS4100-19-001
25-MISC FUEL FILTER CAST BRACKET THAT BOLTS TO ENGINE SIDE (WITH FILTER)
26-2 MISC MANIFOLD PREHEATER ELEMENTS
27-THERMOSTAT MARKED 11-5-155 GA---70 DEGREES C
28-STARTER WITH SOLONOID MARKED QDD100C3 ??-2KW-12VOLT WITH 2 MOUNTING HOLES
112 MM ON CENTER AND OVERALL LENGTH IS 11 1/2 INCHES AND 3 7/8 INCH DIAMETER
29-STARTER WITH SOLONOID MARKED QD1328CL??-12VOLT WITH 2 MOUNTING HOLES
120 MM ON CENTER AND OVERALL LENGTH IS 12 1/2 INCHES AND 4 1/2 INCH DIAMETER
30-STARTER AND SOLONOID MARKED QD1308 --12VOLT-3KW
31-1 SLIDE GEAR SET FOR A 222 THAT IS USED TO ENGAGE THE PTO--130 MM DIAMETER 51 TEETH
WITH ANOTHER SPLINED SLIDE GAER IN THE CENTER WITH 16 TEETH
   / Few Jinma parts for 22 to 40 hp tractors #5
2018 BIG TEX 70CH 84" X 20' CAR HAULER TRAILER (A51247)
2018 BIG TEX 70CH...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
PREDATOR INVERTER 4550 WATT GAS GENERATOR (A51248)
PREDATOR INVERTER...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
2R PLANTER W/ COLE PLANTERS (A51247)
2R PLANTER W/ COLE...
