cowboydoc
Super Member
- Joined
- Dec 23, 2000
- Messages
- 6,725
- Tractor
- JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
I've had quite a few emails asking me about fertizlizing pastures so I thought I'd post here and let everyone know what I thought. Your best bet is to fertilize right now while the weather is pretty wet. The best to use is just the dry fertilizer that is in the pelleted form. You can even leave your livestock on with no problems. Ideally you would like to put your fertilizer down and then have it rain in the next few days.
As far as mixture goes get a soil sample. Alot of soil only needs nitrogen and doesn't need P/K. It will come in a ratio of the three. My pastures all I need is nitrogen. So I just get a 40/0/0 mix. If you don't want to soil test I would do a 40/40/40 mix. Remember though the nitrogen is the cheapest component. If you don't need the P/K then don't get it.
As far as buying call one of your local coop's. They will give you a per ton price and it should be between $170 and 230/ ton on the nitrogen only. It all depends on how much you buy. It will be quite a bit more if you need P/K. Usually the more you buy the cheaper it is. Call around too because it will vary quite a bit. They will fill a hopper for you which you can just drag around your pasture with a tractor or a pickup. You just set the amt. you want per acre on the back of the hopper and you are ready to go. Figure at 40 units that will be about 87 kbs. per acre. Don't go above 50 units though because you have a bigger chance of burning your pasture. Also don't go with liquid no matter what anyone tells you this time of year as it will burn your pasture as well. The time to do liquid is in the fall, winter, or spring after all growth has stopped. Even then I don't like to do it that way as you lose some of it. Putting it on dry right when the grass is coming up will do wonders. Just make sure you apply when there is some rain in the forecast.
That's all I can think of for now. If any of you that emailed have other questions just email me again.
