snohobigdad
- Joined
- Apr 28, 2013
- Messages
- 116
Hi, I am in a bit of a quandary. I don't mind spending money on the right tool for the job, as long it will last. I have a JD2305 that I use for my mowing work around the house. I have pull behind spreader that does leave something to be desired.
I have been trying to research the 3pt hitch type over the past week without much luck. The Countyline brand at Tractor Supply looks like it will fail quickly. They want $500 and change. JD sells the Frontier and Rankin brands. Frontier is a metal hopper an the Rankin is plastic. Both of these are in the mid $800 range. Does anyone here have any experience with these two? Positive and less than positive feedback is appreciated. I will spend the extra buck because the dealer is a mile from our home.
Lastly, if not these two options, what are you using and do you recommend them? I can do tow behind, but it seems to struggle across uneven and sloping areas.
Thanks for your time and expertise!
Jim
Jim
