Ferguson TO 30 help needed
   / Ferguson TO 30 help needed #1
Bigjohn76
IL
54 Ferguson TO30
Hello, just pulled the oil pump to rebuild on this tractor, and saw that the thrust washer was missing. Went ahead and pulled the engine, and crank has worn off the inboard mounting surface on the block that the washer attaches to. Is there any way I can use a set of flanged fron main bearings from a to20 to make this work, or is there another solution to this problem? Any help would be appreciated. Thanks!
thanks deerseeker001!
150' 1-1/2" 325PSI Hose (A52384)
150' 1-1/2" 325PSI...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2011 VANGUARD 53x102 DRY VAN (A53426)
2011 VANGUARD...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
