Hello, just pulled the oil pump to rebuild on this tractor, and saw that the thrust washer was missing. Went ahead and pulled the engine, and crank has worn off the inboard mounting surface on the block that the washer attaches to. Is there any way I can use a set of flanged fron main bearings from a to20 to make this work, or is there another solution to this problem? Any help would be appreciated. Thanks!
