Ferguson 20 coolant flush and change
   / Ferguson 20 coolant flush and change #1
Emmet vintage
Meath
ferguson TEA 20, Fordson Dexta
Hi just wondering all the steps i should go through when changing the coolant on my 20?
Any reply appreciated
Anything at all would be great as i'd like to get this done before the cold weather really sets in :)
   / Ferguson 20 coolant flush and change #3
Get it to Temp and drain and refill with 50,50 mix.:thumbsup:
   / Ferguson 20 coolant flush and change #4
if you want to go whole hog, after you drain it. backflush the block and radiator with your garden hose. heck.. might even sacrifice a gallon of vinegar in there with some water and a few more minutes of run time.. then drain and flush.
pre mix your af 50/50 and refill. run to burp.. and top off.
if theremo or hoses and belt looks bad. this si the time to replace them.
Ok will tackle that job tomorrow thanks for the replies
Another question. The breather on the left hand side of the tractor what is the proper way of cleaning this?
   / Ferguson 20 coolant flush and change #7
oil bath air claner.. it will have metal floss in it. some models are easy to remove.. some not. if the removeable floss style. celant he canister in solvent.. floss too. reassemble.. oil and go. solvent like kero, mineral spirits or diesel.
can submerge the entir thing in a parts washer and slosh around if it is the style hard to take apart. again. drip dry.. then oil and go
Ok cheers :) any other maintence you would recommend for the winter?
   / Ferguson 20 coolant flush and change #9
the usual.. oil and filter change. check coolant. top off and charge battery to prevent freezing.
air tires. .. winter is a good time to repack front wheel bearings and adjust axle nut.. lube all zerks.. etc.. reset points.. clean up electrical.. this way she's ready to go when needed. ( adjust brakes too! )
Most of tht is done except the brakes. Just out of curiosity how hard would it be to get the tractor starting with a key (currently starting on the gearstick)
CFG Industrial SAII100 (A50123)
CFG Industrial...
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
2021 John Deere 1023E Tractor (A52384)
2021 John Deere...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
