djradz
Veteran Member
I have an old Fergeson Sherman 14A plow that I thought was a two-bottom 14" plow. However, my cousin did a measurement and although the cutting edge for each moldboard is about 15" long, it certainly will not cut two paths each that wide, because of the angle. It looks like q path of about 12" or so will result for each of the two bottoms. I also notice there's a gap of about 4-5 inches between the two. I'm wondering, do I truly have a complete 14A plow or has someone fitted it with parts from a 12"? Although I've always plowed pretty deep, it looks like if I didn't, I'd have a path of unplowed ground running down between each moldboard. Should there be some space? Should the 14A cut two 14" wide paths?
