Fencing in A Creek Bottom
/ Fencing in A Creek Bottom #1
Nromes
NC
LS XR4040
We have a field next to our creek where the ground usually stays moist. I understand posts will not pack in tightly. What would be the best way to fence in the field, considering the most should? Wooden posts or metal t-posts? Or is there another way?
/ Fencing in A Creek Bottom #2
What animals, etc. are you fencing in or out? Or is the fence just a boundary marker?
Bruce
/ Fencing in A Creek Bottom #3
You should check with your state. Navigable waterways are the property of the state so says the Feds. And it doesn't need to be navigable all year. Most are open to the public and against the law to restrict access.
In Texas a stream is public if it is "navigable in fact," "or navigable by statute." There is no precise test for whether a stream is navigable in fact. The term is based on the idea of public utility. One court has observed that "waters, which in their natural state are useful to the public for a considerable portion of the year are navigable."
/ Fencing in A Creek Bottom #4
I would think metal T posts would be the better option. I have several wood split rail posts that cross a wet drainage area, and they rot out in a few years.
/ Fencing in A Creek Bottom #5
Could be enough rock in a creek bottom to make it tough to use a post hole digger. I would also lean toward T posts.
/ Fencing in A Creek Bottom #6
Bruce
agree 100%.... what I would do to keep in a randy bull would be much different than what I would do for property marking, etc...
/ Fencing in A Creek Bottom #7
Dry pack the holes with cement would be my thoughts.
/ Fencing in A Creek Bottom #8
We fence creek bottoms with t posts and have cattle in there no problem. Continue on as normal. We run over 3,000 head. No fence problems from a creek bottom.
/ Fencing in A Creek Bottom #9
I think it depends on flow, and the animals.
In North Carolina, I believe that you need to be able to get a boat up the stream, though it seems silent on whether floods count;
f a body of water in its natural condition can be navigated by watercraft, it is navigable in fact and, therefore, navigable in law, even if it has not been used for such purposes.”
When I have fenced creek bottoms, we didn't put any posts in or near the water, and used slats and wire to make a "hinged" section that would lift up and flatten downstream. That avoids many, but not all snags. YMMV!
All the best,
Peter
/ Fencing in A Creek Bottom #11
I used metal T-posts to fence my 80 acres. 655+ - 145 gauge T-posts. I did this in 1982 and all were installed with a very heavy, manual post driver. The posts and fencing still stand - straight, tight and true.
I do have a wet area. About 120 feet with eight or so T-posts. Because the posts are exposed to seasonal wet/dry conditions - they "corrode off" - at the ground level - every ten years or so.
I go into this area - pound in new posts and tie off the barbed wire fencing to the new posts.
I would definitely recommend metal T-posts. Easy to drive - hold fencing well - simple to replace on a routine maintenance schedule.
2020 DRAGON ESP...
UNUSED RAYTREE RMBD72ST-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
UNUSED RAYTREE RMSG29 HYD STUMP GRINDER (A60432)
UNUSED RAYTREE...
14C SCRAPER (A58214)
UNUSED FUTURE EXCAVATOR COUPLER (A60432)
UNUSED FUTURE...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
