Fencemen, your advice please?
   / Fencemen, your advice please? #11
Why would you want advice from a frenchman? ;)
   / Fencemen, your advice please? #12
Fence's don't have to be level, they have to be straight. There's a difference.
I use T-posts to pound in for my end posts on each property line, beyond the last post. Pound them in. Set the string between the two. It has to be VERY TIGHT. If i'm building a rail fence, where the height matters I also like to set the height too at this time. I set each string at the height I want the posts to be at using a tape measure. If you go more than about a 100 feet, you have to put posts in between because the string will sag.
If you are building a picket style fence, don't worry about the height of the posts until after you finish, then take a big old circular saw and whack the tops off. (much faster)
The trick is to get the post level in all directions and directly centered under the string. Sometimes it involves extra digging. Then, once it's set (and it takes two people to do this efficiently), I take scrap wood (actually those cheap 1x4x6' cedar pickets) and nail them in for 3 or 4 directions at an angle so it holds the post straight and level. This is the key. Then, your cementing person can follow behind without worrying about moving the post, or you either as you set the next posts.
does that help?
Oh, and being off side to side is much less noticeable on a rail fence than being off on height. It should gradually slope and follow the lines of the land.
HTH
   / Fencemen, your advice please? #13
I second everyone's opinion about using a tight string between 2 posts. However, I have a small but important point to make. When setting the post, don't let it touch the string. If you touch the string on the first post you will almost always push out the string a tiny bit. The next post a tiny bit more, the third more etc. After 10-15 posts you will look back and go what the he__ happened and your posts are out of line. Don't ask me how I know this.:eek:
Also if your setting a smooth wire or barbed wire fence, use the wire as your string. A level can be used initially but after several posts you will get good with just eyeing the post to get it right. Your not building furniture my dad used to say.
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
6 ROLLS OF CONDUIT (A50854)
6 ROLLS OF CONDUIT...
2014 MACK CXU613 MID-ROOF SLEEPER (A50854)
2014 MACK CXU613...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
