Fence Rail Splitter
   / Fence Rail Splitter #11
My current thought is a 6-8" channel laying on the web, thus using the flanges as an anti-roll feature, mount a 2 way cylinder to push into a 4 way splitting head,...
Your channel will have to be welded to the top flange of an I-beam or something of similar stiffness. By itself it is way too flexible. Most log splitters use the top flange of the I-beam as a linear guide for the pusher. Having the channel there will make that a little harder.
The horizontal wedge of the 4-way might benefit if it is height-adjustable and removable. Some high-end splitters have that feature.
If the wedge is also on a linear guide that is pinned to the beam, you can pull the pin to ratchet the process if needed. I don't like the idea of using log spacers or splitting multiple firewood chunks because the stack could buckle explosively.
Even if running off a remote valve you will want to leave that valve actuated and add a splitter valve where you are working. The Prince 3060 regenerative valve can save lots of time. http://www.baileynet.com/product/9194
Thx's for the input Brad - yup could be creating more problems than I solve with channel only. I'm warming up to the concept shown in a French manufacturer you tube video. Also agree the adjustable splitting head is a must. ENC mentioned earlier about cables and winch, I might rethink along those lines using a concept in the video address below.
Appreciate your thoughts
Mike
MecaPerf
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
J & M 30' Head Cart (A50514)
J & M 30' Head...
