ctpres
Need to build several fences with livestock on both sides. Usually will be sheep but on occasion med. & full size cattle. Is it good/bad idea to alternate posts on either side of fence with fence down middle?
radman1 said:In general, the wire goes on the same side as the animals. This way if animal leans or pushes on fence, the wire is less likely to be knocked off the post. With animals on both sides, I guess weaving the wire is OK but probably more work since the guy tying or stapling the wire will have to work from both sides of the the fence. Cattle will push harder than sheep on the fence and maybe the wire should be on the cattle side.
ctpres said:Need to build several fences with livestock on both sides. Usually will be sheep but on occasion med. & full size cattle. Is it good/bad idea to alternate posts on either side of fence with fence down middle?
