tallyho8
Super Member
- Joined
- Aug 1, 2004
- Messages
- 5,256
- Tractor
- Kubota L4400, Kubota ZD326
I'm putting in round treated fence posts. Should I put them in upside down or right-side up? The posts are narrower on the top and wider on the bottom.
The way that I put fence posts in is that I use my tractor post hole digger to dig a hole about an inch or two smaller than the diameter of the post and then I make the hole about 30 inches deep if I want to bury the post 36 inches.
Then I set the post by the hole and push it in with my front end loader. This makes the post very tight and I do not have any hole to backfill.
This method works perfect if I put the poles in upside down but some have told me it is best to put the posts in right side up with the wide end to the bottom. If I do that then it makes the hole wider than the post and I have to backfill it and it never seems as tight.
Your opinion?
Your opinion?
