OP
HighLoader
- Joined
- Jan 12, 2007
- Messages
- 49
- Location
- Aguanga, CA
- Tractor
- New Holland TC40DA, Kubota K008-3 excavator
Only 1.7? All this time I thought it was 1.75 times stronger. Can't believe I've been doing all that tamping for just 1.7. Darn!!CharlieTR said:I agree with weldingisfun concrete every fifth post.
Do you expect a lot of big cracks in the soil?
Around here the late Summer cracks can swallow a fance post whole. Thats why I would concrete every 5th post.
It would be good if you can find a way to drive the posts in.
A driven post is 1.7 times as strong as a tamped post.
My wife and I used one of those Earthquake augers to put in 1.5 miles of posts, Now we have a tractor and PHD. Still have the Earthquake, just in case I need to sink a hole somewhere that tractor can't go.HighLoader said:I understand those post drivers are fast. With that kind of pounding doesn't the top of the post get smashed or mushroom? I am putting nice metal caps on the top of ever post to keep the rain out and give it a finished look.Everyone is going to laugh at me....believe it or not I have been useing a one person "earthquake" gas auger I bought at Lowes for $225 and a 6 inch auger bit for another $100 bucks. I was useing a Gearmore PTO Auger on my other little New Holland TC24da and it was hard to position and would get tippy on some of the slopes. The down preasure was not good either. I did about 30 or 40 holes with it and then tried this little hand held auger and swithch over. I will drill five or more at a time so I don't have to keep pull staring it...even though it starts pretty easy. I use a string line with stakes and it is much easyer and faster to position each hole along the line with the hand held auger than it was with the one on the tractor. I will admitt it is more exercise. Also, if I hit a root or rock bigger than my fist and am day dream'n I could hurt a wrist....I did sprain my wrist one time that way and have been careful ever since. I have thought about getting a hydrolic Auger or a post driver but have got pretty good at doing it this way. So I have a $26,000 tractor and a $16,000 excavator and using a cheap $225 post hole digger!!!![]()
Brian
HighLoader said:I have started fencing our 5 acre and 20 acre property, the perimiter and interior. I am using 2,7/8s steel oil well tubing for the posts. I have been drilling 2 foot holes and then setting them in concrete. Yesterday I tried setting a couple without concrete. I used a steel rod to pack the dirt in around the post. I was suprised how secure it was. Without the concrete, will the posts loosen and lean over? Without the concrete to protect the post how long will the post last? Can I coat the post with something before I put it in the ground? My hope is that I can get a good 40 years or more out of these posts so when I am in my eighties I will not have to do this all over again! Anybody out there with some advice? Thanks![]()
My farmer friend has one of those and I got to watch him use it this past fall. I have to agree 100% with ya. The "proper length" piece of pipe...driven down with one of those makes concrete around the post a waste of $$ and effort.gerard said:Fencing that much I'd also consider a post pounder. They have a cap that goes over the top of the pipe and the weight actually hits the cap, not the pipe directly to prevent mushrooming. All commercial fence companies that install chain link fence with metal posts ( which is close to what you're doing with the oil pipe) use a pounder. It's quicker, tighter, and you can plumb as you go. (The pounders articulate in all 4 directions so you drive at any angle you want). There's also no backfilling, tamping etc. When you're done pounding you're done. I bet you can do a pole every 5 minutes with a pounder! BYW - I echo the other sentiments about your land - beautiful!
Egon said:Concrete will definetly help hold the posts more securely.
