ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,724
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
That middle picture tells the story. The wire bracing must be in an X pattern. As they are now - they are pulling that center post right out of the ground.
For any corner or change of direction I always use a rock filled gabion. Its about four tons of rock - stacked in a 4' x 4' x4' cube. I use old rejected industrial shelving. It is in 4'x16' chunks with expanded metal as the decking of the shelf. Cut & fold and you have a four sided cube. Locate where needed and fill with rock.
Wow!!! Tremendous amount of work to turn a corner. Got any pics?? Thanks.
