Fence Post Caps
/ Fence Post Caps #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Can anyone recommend a place to by fence post caps for the top of 4" x 4" posts? I'd like to put them (plastic/vinyl) on the top of the posts to shed water.
/ Fence Post Caps #2
I was at Lowe's today and, on a cart I saw being pushed down an aisle, I saw some copper caps for 4" x4" posts. I would check with them, if they have the copper I would think they have the cheaper plastic.
/ Fence Post Caps
Thanks, Brad. I stop by Lowes today.
/ Fence Post Caps #4
</font><font color="blue" class="small">( Can anyone recommend a place to by fence post caps for the top of 4" x 4" posts? I'd like to put them (plastic/vinyl) on the top of the posts to shed water. )</font>
Just curious here. If you are using wooden posts why put a cap on them? The post will rot out at the bottom long before any damage is done from water on the top. If it is just an appearance thing, I can understand it.
Harry K
/ Fence Post Caps
I was thinking that caps would prevent the PT posts from rotting from the top.
/ Fence Post Caps #6
Mike,
How many posts do you have that you want to cap?
If you don't have too many to do, why not just take a circular saw, or if they're out in the field and you don't have a generator in your FEL, a chainsaw, and just cut an angle at the top of the post? A simple 45 degree cut would be sufficient to let the water run off.
Just an idea. /forums/images/graemlins/smile.gif
/ Fence Post Caps
As someone else suggested, the posts will rot at the bottom or ground level before rotting from the top. Makes sense to me. /forums/images/graemlins/cool.gif BTW, I have 187 posts.
/ Fence Post Caps #8
Those caps are expensive little boogers... From $2-$5 a pop... 187 at $2 each is $374. Maybe I'm cheap, but that's a lot of money!
/ Fence Post Caps
The plastic caps at Lowes were $1.16 each. Glad I wont be buying any. /forums/images/graemlins/laugh.gif
/ Fence Post Caps #10
I have seen a lot of fences where they used flashing to cover the tops of the posts. It's kind of ugly but I imagine it's cheaper.
/ Fence Post Caps #11
</font><font color="blue" class="small">( I was thinking that caps would prevent the PT posts from rotting from the top.
)</font>
Had a water pipe break in the pasture. Digging it out I grabbed a PT post (ground rated) that I put in about 10-15 years ago. Nothing left below ground, solid as the day it was new above ground, held up by the wire. Capping one except for appearance is gilding the lily in my mind.
Harry K
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
2019 GENIE S-60XC' TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC'...
SET OF 26' & 36' GATES (A62131)
SET OF 26' & 36'...
