Eric_Phillips
Platinum Member
I am hanging some flex fence. I have been setting the end post then a brace post about 6' from that. I then put a 4x4 between the two near the top and then a diagonal brace going down at a 45 angle. Now my problem is I have a swale and one of the diagonal braces will be just about in the bottom of the swale. So I figure I have two options.
1) Put in the end and brace post about 6' apart. Put brace across top then a tension wire from the top of the brace post to the bottom of the end post.
2) Put in end post then two brace posts each 10' apart to span the swale with braces across the top of all three. Then a diagonal brace down to the ground.
Any thoughts which will work best?
There is about 1' of soil on top of sand. The water level is about 3' so the ground is soft.
