fellow ck10 (ck2610) with OUT telescoping lower 3pt links
   / fellow ck10 (ck2610) with OUT telescoping lower 3pt links #11
What's the reasoning behind telescoping links vs fixed length links? I'm considering a CX2510, so I'm curious.
   / fellow ck10 (ck2610) with OUT telescoping lower 3pt links #12
So you don’t have to be perfectly lined up when hitching. Release the ends so they float, attach implement, then back up until they lock in place.
   / fellow ck10 (ck2610) with OUT telescoping lower 3pt links #13
So the telescoping links kinda lose that advantage if using a quick hitch on the 3PH?
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2006 FREIGHTLINER CST120 (INOPERABLE) (A55745)
2006 FREIGHTLINER...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2021 Toro MBTX 2500S Tracked Mud Buggy (A54865)
2021 Toro MBTX...
