fel
robert j
mason nh
yanmar 336d
yanmar 336 d had the front end controller rebuilt last year .still leaking buy when back grading with bucket it will just roll over .and when lifting up it wants to dump the load . single lever .can I put on a two lever spooler say 3000 psi lifting from tractor supply . and what would I really need to buy .
/ fel
that is the one I was looking at when I made the post. just was not sure that it would work. I will check with the local yanmar dealer this week end. have not had much luck with them getting parts. also need a tie rod shaft the tie rod on left side striped out so I tighten it the best I could and drilled it and put a 16 penny nail through it .it works . need brakes they are shot to/
Yea look up Hoye Tractor parts, which is the link Winston Posted. They have everything you need, great prices and excellent customer service! Forget you local guy if you can get it all sitting in your chair and have all your questions answered and get the best price all while doing so then why not. Its best to support folks that are there to help and support you. They do this by recreating and also reengineering parts that are obsolete or can not be sourced from original sources anymore or parts that are prone to break, they make some of these parts inhouse, like the spindles for some 2wd machines. They also have made a spacer kit to get the rear tires out wider for a more stable stance.
YES! Support Hoye Tractor Parts. They are great folks to deal with and will provide great customer support!!!!
