FEL wont stay up
   / FEL wont stay up #1
stan33
Hi,
After rebuilding the power steering pump and cylinders, I raised the tractor up on the FEL to get the air out of the p/s and the tractor sunk back down straight away.
As the FEL goes up fine, if a bit slowly, is the cause likely to be the FEL cylinders? They aren't leaking externally.
Thanks
   / FEL wont stay up #2
Could be cyl piston seals or valve spools.
Switch work port hoses and see if the operation is the same the same.
   / FEL wont stay up #3
J_J
If piston seal is leaking on boom cylinder and boom settles down where does the extra oil move to as cylinder rod moves into barrel taking up area that oil bypassed by piston would require?? In this question I'm presuming that control valve & rod seals are holding pressure IE not leaking.
Thanks,Jim
   / FEL wont stay up
Please forgive my noob-ness but do you mean the top hoses?
The unit says Vickers on it but no part number. Do you think there is a repair kit for it?
The FEL was built by a Massey dealership in this state, probably 30 or more, years ago. Fortunately the cylinder manufacturer is still in business in my state capital and they carry out repairs, hopefully under warranty:).
   / FEL wont stay up #6
How many times have you had the loader raised and lowered since the work?
   / FEL wont stay up
The work was on the power steering which is a separate closed system not on the FEL hydraulics
I was aware that there was an issue when I bought it as the seller put the FEL on a drum so that I could get in to clean a lot of muck off, to get a better look at the engine.
Within half an hour the drum was getting pushed into the floor. I asked the Massey dealer nearby the seller what he thought it was caused by and he said it should take the FEL overnight to go down by itself not half and hour and so was likely to be the cylinders not anything else. I wanted a second opinion from the forum before I start sending parts away to be rebuilt or I order parts to rebuild myself if that's do-able for the novice.
   / FEL wont stay up #8
Please forgive my noob-ness but do you mean the top hoses? <img src="http://www.tractorbynet.com/forums/files/hydraulics/440500-fel-wont-stay-up-hydraulics-008a-jpg"/> The unit says Vickers on it but no part number. Do you think there is a repair kit for it? The FEL was built by a Massey dealership in this state, probably 30 or more, years ago. Fortunately the cylinder manufacturer is still in business in my state capital and they carry out repairs, hopefully under warranty:).
JJ means switch the hoses that control the bucket dump and the ones that raise the loader. I don't think you have quick disconnects, so it would be done at loader control valve. So the controls would be opposite to what they are. Odds are that both sets off seals in valve are not worn. This would help determine if it was seals in valve or Pistons. Good luck. Most newer tractors have removable loaders, so they have couplers that are easily swapped around.
   / FEL wont stay up #9
There are no replaceable seals on a spool valve that can leak that will allow a hyd cylinder piston to move. Worn spool lands &/or valve housing can let cylinder piston move.
   / FEL wont stay up
Thanks guys.
There 'aint nothin quick disconnect about this loader!
As those hoses at the valve are at almost the highest point, I guess there shouldn't be too much oil loss but will I still have to bleed the system and if so how?
Honda 24hp Brush Truck Pump (A57454)
Honda 24hp Brush...
MILLER 330 A/BP ELECTRIC WELDER (A58376)
MILLER 330 A/BP...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A56858)
2012 Ford F-550...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58216)
HYDRAULIC TILTING...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
