fel valve--2p-40 joystick
/ fel valve--2p-40 joystick #1
jonyyuma
Elite Member
35 miles North of Memphis,TN
kubota L3000dt, ford 8n1952
Help, I need a little info on my joystick control for the FEL. it is 2 piston, and single lever. Square rubber boot,on lever. 2P-40 casting on side.No other markings except for P at bottom and TN at top. My question is which line is the return to tank line, and who made it? I want to add a Prince 10 micron filter for cleaning the hyd oil. I believe the loader is New Holland for a TC35 tractor? I would like to find out, without having to try the bucket method and losing oil. Thx. Jy.
Okay, from my limited research this appears to be a Prince joystick controller. I don't understand why it doesn't have a number identifier on it? Dalton diagram almost shows it flat and with the words out at the return. I did see a P so maybe that was in place of IN?
/ fel valve--2p-40 joystick #3
P=Pressure or IN usually.
Can't up trace the hoses?
They are also called "spools" rather than "pistons", that may help your search some.
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
25 Traffic Cones (A65583)
25 Traffic Cones...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
