fel valve--2p-40 joystick
/ fel valve--2p-40 joystick #1
jonyyuma
Elite Member
35 miles North of Memphis,TN
kubota L3000dt, ford 8n1952
Help, I need a little info on my joystick control for the FEL. it is 2 piston, and single lever. Square rubber boot,on lever. 2P-40 casting on side.No other markings except for P at bottom and TN at top. My question is which line is the return to tank line, and who made it? I want to add a Prince 10 micron filter for cleaning the hyd oil. I believe the loader is New Holland for a TC35 tractor? I would like to find out, without having to try the bucket method and losing oil. Thx. Jy.
Okay, from my limited research this appears to be a Prince joystick controller. I don't understand why it doesn't have a number identifier on it? Dalton diagram almost shows it flat and with the words out at the return. I did see a P so maybe that was in place of IN?
/ fel valve--2p-40 joystick #3
P=Pressure or IN usually.
Can't up trace the hoses?
They are also called "spools" rather than "pistons", that may help your search some.
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
(INOP) INTERNATIONAL 1066 TRACTOR (A64278)
(INOP)...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64278)
KNOW BEFORE YOU...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
