Ballast FEL use with no ballast
   / FEL use with no ballast #21
OK, next cheap option, 3pt drawbar
Those things are scary. 3PH don't usually have down pressure. I tried one once witha trailer load of wood and had to stop quick. The trailer tonge jerked the drawbar upward and changed my center of gravity. I was going downhill and it wasn't pretty. /forums/images/graemlins/ooo.gif
I'd thought of that, too, but figured one good reason I couldn't do it was enough. On the positive side, if you do want to use that method all you need to do is attach a chain from your drawbar up to it to eliminate the 'bounce' you mentioned. /forums/images/graemlins/smile.gif
   / FEL use with no ballast #23
Good idea. I hadn't thought of that. /forums/images/graemlins/wink.gif
   / FEL use with no ballast #24
I was reading one of your past posts on ballast box weight, And was wondering on how much weight do you say you have in your ballast box, I'm getting ready to build my own and was wondering how heavy should I make it .
TC24DA 12LA 60"MMM
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2011 CATERPILLAR 535C SKIDDER (A52707)
2011 CATERPILLAR...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
DRILL PRESS (A55745)
GODWIN 6 HEAD PUMP (A55745)
GODWIN 6 HEAD PUMP...
