FEL use for brush/debris pile moving ?
   / FEL use for brush/debris pile moving ? #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
I have some property that was partially logged. There are debris piles scattered many places naturally rotting. I know a dozer is probably best tool. Can a JD 5065e with 553 FEL be used to push these piles into burn able piles? My main question is really how much pushing can you do with a fairly heavy duty FEL (compared to a compact 300 CX) without damaging FEL? Also I plan on getting the global carrier and HD bucket. The global carrier has a horizontal structural member connecting the 2 FEL arms vs the JD 500 really relying on bucket for lateral forces between arms. I am a structural Engineer and never owned a tractor and realize nothing beats experience. So basic question is can FEL be used for pushing vs material movement like dirt, aggregate, etc. And for you guys that manage forested areas, will I regret it if I don't go ahead and get a 4 in 1 bucket or grapple up front? I need a bucket more than grapple as a grapple can't move material like dirt. But I would like thoughts on this topic. Thanks in advance
   / FEL use for brush/debris pile moving ? #2
I use my 400cx fel on the 4520 to move brush piles a lot. Since I don't have a brush fork, I wind up using the pallet forks a lot with tight brush this works well and doesn't pick up extra dirt. With the 4in1 bucket I can move the stuff that is too loose to pick up with just two forks. Problem is you won't get much per bite. A brush grapple is the way to go if you have enough money.
After logging in Oregon, we are required to leave a few brush piles as "habitat", I call them fire jackpots.
   / FEL use for brush/debris pile moving ? #3
A set of long pallet forks really does a quick job
   / FEL use for brush/debris pile moving ? #4
I agree,:thumbsup: but would like to add one thing. I have 48" forks and works great, but I would try to get some kind of flat sheet metal or something to help keep branches from poking through and puncturing the grill and radiator. I didn't do that to mine, and still haven't, but I dinged up the radiator from an errand branch and also broke the 1" solid tube connecting the loader arm pivots together. Just something to think about, but with my 3720 I pushed piles 10-12' high quite effortlessly.:drink:
   / FEL use for brush/debris pile moving ? #5
...will I regret it if I don't go ahead and get a 4 in 1 bucket or grapple up front?
Absolutely!
Since you already have a bucket for moving dirt, I suggest a grapple on your FEL. I have moved an insane amount of brush with my tractor which is smaller than yours. You'd be absolutely amazed at how much work you can get done, and how fast, with a dedicated FEL grapple. Skip the 4 in 1.
Your tractor would be a brush piling MACHINE with a good FEL grapple. Just watch your undercarriage from logging slash.
Any suggestions for grapple manufacturer? Get a JD, Woods ?
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
24008 (A53422)
24008 (A53422)
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
PALLET OF 15-BLACK GROUND PROTECTION MATS. 4FT X 8FT (A53843)
PALLET OF 15-BLACK...
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
