FEL upgrade, can it be done.
   / FEL upgrade, can it be done. #1
idaho2
SW WA / North Idaho
Mahindra 5530 4WD Turbo - Gear,
Have a friend with a (used) 35 hrs. 2014 6110 cab. Is wondering if he can upgrade to a ML266 to replace the 161 loader. Found out the 161 loader does not reach like the ML266 does 128".
idaho2
   / FEL upgrade, can it be done. #2
idaho2
Not without a lot of specialized fabrication work. You would have to build all the mounts etc as well as figure out the hydraulics.
   / FEL upgrade, can it be done. #3
Unfortunately the 166 loader fits TYM made Mahindras and the 266 fits Mahindra made Mahindras. From what I can find the loader on the 166 had 400lbs more lifting capacity than the 266.
He has the 161. I have a 78" bucket and can lift to 10' 6" with the ML266. He may not be able to clear his dump truck box. From what I found is that the 161 is a specific loader for the 6110. Am I correct in that finding?
Idaho2
   / FEL upgrade, can it be done. #5
Idaho2
That is correct. Each loader is specifically designed for one tractor or set of tractors (like the 1533 and 1538 take the same loader)
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
