FEL upgrade, can it be done.
   / FEL upgrade, can it be done. #1
idaho2
SW WA / North Idaho
Mahindra 5530 4WD Turbo - Gear,
Have a friend with a (used) 35 hrs. 2014 6110 cab. Is wondering if he can upgrade to a ML266 to replace the 161 loader. Found out the 161 loader does not reach like the ML266 does 128".
idaho2
   / FEL upgrade, can it be done. #2
idaho2
Not without a lot of specialized fabrication work. You would have to build all the mounts etc as well as figure out the hydraulics.
   / FEL upgrade, can it be done. #3
Unfortunately the 166 loader fits TYM made Mahindras and the 266 fits Mahindra made Mahindras. From what I can find the loader on the 166 had 400lbs more lifting capacity than the 266.
He has the 161. I have a 78" bucket and can lift to 10' 6" with the ML266. He may not be able to clear his dump truck box. From what I found is that the 161 is a specific loader for the 6110. Am I correct in that finding?
Idaho2
   / FEL upgrade, can it be done. #5
Idaho2
That is correct. Each loader is specifically designed for one tractor or set of tractors (like the 1533 and 1538 take the same loader)
2006 FORD F-250 (A52472)
2006 FORD F-250...
2024 Victor X-PRO Mini Dirt Bike (A50324)
2024 Victor X-PRO...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
