FEL teeth - yes or no?
   / FEL teeth - yes or no? #1
TomIre
College Grove, TN
Branson 3725
What are the pros and cons of teeth on an FEL? I'm guessing there are situations/tasks where teeth are an advantage and times where they are not? What should I consider?
   / FEL teeth - yes or no? #2
Get a tooth bar, on when needed, off when not needed.
Makes digging much easier.
   / FEL teeth - yes or no? #3
Times 2
I had a skid steer with a plain bucket and also a tooth bucket. After using the tooth bucket, I rarely used the plain bucket.
1. The tooth bucket pierces the soil/sod/pile much better than a flat straight bucket edge. It is like having both more horsepower and traction.
2. It's like having a rake when trying to smooth a surface. This is especially true if the dirt has lots of sod and roots mixed in. With the bucket tilted you can use the bucket like a comb. You can have the bucket level and still do smooth back blading.
If you have a bolt on tooth bar, you can always remove it when you want a plain bucket edge, but I'm guessing you will leave it on most of the time.
   / FEL teeth - yes or no? #4
Times 2
I had a skid steer with a plain bucket and also a tooth bucket. After using the tooth bucket, I rarely used the tooth bucket.?
2. It's like having a rake when trying to smooth a surface. This is especially true if the dirt has lots og sod and roots mixed in. With the bucket tilted you can use the bucket like a comb. You can have the bucket level and still do smooth back blading.
I'm assuming you meant rarely used the plain bucket.
I've got Pirahna's on both tractors MOST of the time. I can even slip my clamp on pallet forks over them for light loads. I've taken them off for projects which require a lot of scraping.
   / FEL teeth - yes or no? #5
I prefer a smooth bucket for spreading gravels or scooping off a solid surface. For pretty much everything else I prefer teeth. I got to choose between a toothed or a smooth bucket on the CTL. I got the toothed and smile every time I use that thing. I’d make the same choice again.
   / FEL teeth - yes or no? #6
Having teeth is a night and day difference when digging. I have two buckets one with and one without. Anytime I am moving a lot of dirt I use the tooth bucket. Anytime I am grading I use the smooth bucket. You can grade with a tooth bucket but I prefer the smooth. For what I do if I had to choose one it would be the one with teeth. They do make bolt on tooth bars but I hate things like that. I am lazy. I don’t like spending time configuring my machine different ways for different tasks. I like to hop in and go. No they are not hard to take on and off and the one I had on my old tractor only had two bolts but still I don’t like having to stop work and go get tools and bolt or unbolt crap to finish a task. I have a hydraulic coupler for my bucket and once I get to working I may change attachments several times and never leave the seat.
   / FEL teeth - yes or no? #7
Couldn't agree more. Plain and simple. Night and day difference when digging. The teeth are also a great addition when clearing old trails of fallen tree branches and pushing tree trunks out of the way, etc.
   / FEL teeth - yes or no? #8
Sand and snow for smooth bucket. I use teeth for everything else.
   / FEL teeth - yes or no? #9
Maybe.
Below is the right and the only answer. There are times when teeth are absolutely necessary and other times when they will ruin a job.
   / FEL teeth - yes or no? #10
Well said, with few words.
Another convenience of teeth I have found was for carrying 4x8 sheets of plywood with the tractor by resting the edge of them on the teeth and strapped to the bucket.
The one disadvantage to that is it is more painful banging into the teeth while unloading the plywood with the bucket raised a foot or so off the ground to make it easier to grab the plywood sheets. Don't ask me how I know because aren't we all supposed to lower the bucket to the ground before dismounting the tractor. :mur:
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
JOHN DEERE 661R LOT NUMBER 106 (A53084)
JOHN DEERE 661R...
2025 High Country Cargo 7x16 Enclosed Trailer, VIN # 7FWBE1626S1035340 (A51572)
2025 High Country...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2015 Chevrolet Impala CAR (A51694)
2015 Chevrolet...
