FEL strong but Backhoe Weak... What would cause this? VIDEO
   / FEL strong but Backhoe Weak... What would cause this? VIDEO
Well I got the backhoe out tonight to try and scrape some snow.... bad idea!!!! I did figure out the rear end is not locked and that is worn ag tires suck on concrete. Back the hydraulics. I still haven't checked the pressures but I am pretty sure that my back spool needs rebuilt. A lot of the back cylinders drift, even the ones that i was told were rebuilt. One of the our riggers will pick up the back end the and i can move the back end with the swing function. That kinda tells me that i am getting good pressure back to the spool but maybe not to the cylinders. As soon as these 16" of snow melts i am going to hook up the gauge and see what pressure i am getting to the cylinders. I will keep everyone posted.
I forgot to add that the spool is a gresen v20p
   / FEL strong but Backhoe Weak... What would cause this? VIDEO #13
Here is a PDF of the V20P.
http://www.phtruck.com/download/hvd/HVD-Service-Literature/Gresen-Spare-Parts/V20SpareParts.pdf
It looks like your valve has a no relief plug in the port normally used for a relief.
That means that the BH valve depends on the main relief valve for protection.
You could add one if you like.
You may have a combination of cyl and valve leakage so it might be difficult to get a good pressure reading.
Some parts of that valve can be rebuilt, but if the spools are worn, there is no fix for that kind of damage.
To check the pressure, I would install the hyd gauge in a tee in the IN port of the first valve.
Then you can see the pressure for any spool in that circuit.
Thanks for the link, I was looking at that pdf last night trying to figure out what all i need to be aware of. I found a little better pic in this pdhttp://www.a-lhydraulics.com/Files/V20%20Gresen%20Valve.pdf Here is the pic if my valve v20.jpg
   / FEL strong but Backhoe Weak... What would cause this? VIDEO #15
That picture is for the work ports section of the stacked valve.
Okay, a little update. I finally got a gauge to check my pressure but it ended up being broken. So i figured i would just go ahead and pull the pressure relief valve and found that the spring was (picture Below). I am sure this will lessen the valve pressure which will cause my backhoe not to be strong but my front end loader had plenty of strength and as far as i can tell there is only only one relief valve to the entire machine:anyone:. The valve spool is a Gresen 2712 what a M stamp . Where can i find a new spring? I have searched the net.
   / FEL strong but Backhoe Weak... What would cause this? VIDEO #17
I believe Parker owns Gresen now, so I would call Parker for a part.
I called parker and they were unable to help me without a part number,The only numbers on the valve body are 2712 on the top with the letter M, and 040379 on the bottom. I am not sure is this is a V70 or what. Do you happen to know? I took the broken gauge back today and should have a new one by thursday.
   / FEL strong but Backhoe Weak... What would cause this? VIDEO #19
Ok, here's a quick temp fix for that. Had to do same thing on my no longer available (Italian-made), 2 spool FEL relief valve spring. Grind the tail end of the spring flat, check it regularly with a square, on a flat surface. As close to 90 degrees as possible.
If you have some measuring calipers or micrometer, measure the busted off piece. Also measure the diameter of the spring.
I found a steel bushing at TSC, that was the right Outer Diameter & (close enough) on the Inner Diameter. Had to cut it almost in half, to get a piece just a bit longer than my length measurement (you can always make it smaller, but it's harder to stretch it, when you cut it too short). Back to your beltsander/grinder to square it up (start on the high-side, work to the low-spot).
I put my bushing in first, due to the design of my valve, its just a pocket in the valve-body & no oil flows thru there. Then I dropped the remnants of the original spring in & re-assembled the rest of the valve. Hasn't failed yet! Might be worth a try.
Shadow
   / FEL strong but Backhoe Weak... What would cause this? VIDEO #20
The shorter the spring is cut, the stiffer it will be. You might end up with a fickle relief setting (hard to dial in just right), but it shouldn't pose a problem as long as you can make it bypass at the right PSI. Good work around Shadow.
2015 FREIGHTLINER CASCADIA (A52472)
2015 FREIGHTLINER...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
100 GAL FUEL TANK (A52472)
100 GAL FUEL TANK...
