Loader FEL Self Leveling
/ FEL Self Leveling #11
I think you are going to find that your cylinders are fully retracted at this point and by raising the lift arms the rest is mechanical linkage that keeps the bucket in the same position. It should have a float position if you push the lever fully forward but that will simply lower the lift and bucket to the ground in the same curl position that it was in when you drop it. If the fully retracted bucket control cylinder is not getting the bucket level, at least to the extent of design contact your dealer. NOTE: the front lip of the bucket is not going to be level with the back when lifting (see specifications on amount of movement) as you dont want the contents to drop back on the hood of your tractor. The FEL blade is always going to be lower than the back of the bucket just like in the photo in previous post
/ FEL Self Leveling #12
Found with mine, LS S3010 that the joy stick bolts had loosed up a little allowing for some slack with the operation of the curl/dump, tightened the 3 hex bolts up on the controller and all is fine, don't know if that will help or not. Danny
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
Case 1083 20ft Corn Head (A61307)
Case 1083 20ft...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Chevrolet Tahoe SUV (A59231)
2015 Chevrolet...
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
