Fel rpm
   / Fel rpm
Problem is it's not loose. It's hard packed gravel. I usually have to stop put it in neutral and scratch at the wall with my tooth bar to loosen it. I then can easily dig it out. The tractor just does not have the sheer size and power to go up the bank
   / Fel rpm
I usually use low range and 4th gear
   / Fel rpm #13
I see, every tractor is different, can't give you any advice then, that would help that is. Lol
   / Fel rpm #14
As Jesse stated every tractor make, model and year is different. The dirt we dig is different. I run my DK45SE HST completely different than my 25hp Satoh gear tractor. Mostly it is weight and hp, but HST is a different animal. I sort of wish my DK had a foot throttle for a little extra hp when I need it, but I would have to have a third foot. With HST I sort of learned how to use both hands and feet independently.
   / Fel rpm #15
Pull the pile down to create a bigger loose pile. Then drive into and scoop up.
I leave my throttle set to about 2000, and use low range 1. Once I have a bucket full, before backing up, I switch to high range 1 for transport. Works for me, but I only have two ranges. In this case I use the range control sortof as a shifter. You do have to be completely stopped however. I prefer the low 1 range to reduce wear and tear on clutch while having plenty of digging power.
   / Fel rpm #16
I recently had 10 ton of crushed stone delivered and dumped. I was always trying to find a good gear to push into the pile (2 or 3 Low range) and then transport (4L or 1H). It would be nice if 4L would provide a little more speed -- then low range would be perfect. Maybe just flip between 3rd and 4rth gear.
TOTE OF RIMS (A58214)
2019 MACK PINNACLE (A58214)
2019 MACK PINNACLE...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
9ft 4in Flat Bed (A57453)
9ft 4in Flat Bed...
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
