FEL Quick Attach Blade?
/ FEL Quick Attach Blade? #1
Rory_Rhodes
Georgia
Is there a 6' blade available for the Kubota quick release FEL? I just bought the rear 6' blade, but having a front mounted blade seems to make sense in order to push around dirt and gravel. I also just bought front forks that utilize the quick release/mount of the Kubota 723 FEL. I have searched the different forums but any "been there, done that" advice sure would be useful. Next stop, what Post Hole Diggers and Trailer Hitch setups (for the tractor) should I consider?
/ FEL Quick Attach Blade? #2
Because the blade will be extended out from your FEL mounting could the added torque distort the FEL frame or damage a cylinder???
Several have adapted 3ph quick-hitches to mount to their FEL quick attach to use landscape rakes but I believe their intent was to back-drag and not push dirt.
/ FEL Quick Attach Blade? #4
I have a Curtis blade mounted on my FEL. I does not do a good job of moving dirt. The back blade and box blade works much better.
I have modified a Speeco Quick Hitch to fit my FEL. It allows me to put a landscape on the front. My rear blade is to heavy for to put on the front of my tractor. I have a B2910. Your L3130 maybe able to handle a heavier blade.
There is a 3PH adapter made for skid steers. With the 723 quick attach you should be able to use one of these.
Markham Welding has an adapter.
/ FEL Quick Attach Blade? #5
I was looking at a Kwik-Way FEL quick attach blade for my Mahindra 4110. Basicly the same thing as the Curtis blade.
I mainly want to use it for snow removal.
How has the Curtis worked with snow?
Anybody have the Kwik-Way?
/ FEL Quick Attach Blade? #6
Rory, I have a Curtis 5ft. plow attatched to the front of my Kubota 7610. The plow attatches to the F.E.L. arms inplace of the bucket. The dealer and Curtis both advise NOT to push dirt or gravel with it. The plow is for snow removal only. Now can you push small amounts of dirt or gravel? Yes, so far I have had no big problems, but a rear blade would be so much better if I had one to use. I could see if you were to over use the plow for not it's intended use you could probably damage it and the forks on the tractor.
Thanks for the feedback, from the general consensus, an FEL front blade probably not the best idea. Thanks again for all of the great advice!
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
John Deere 328E (A63689)
John Deere 328E...
2006 Kenworth T800 Tandem Dump Truck, VIN # 1NKDLU0X26J147788 (A65563)
2006 Kenworth T800...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
