FEL questions
/ FEL questions #1
Anonymous Poster
Epic Contributor
Hoping to get some help on FEL's. One local dealer quoted a Woods FEL for my TC18 installed for $3624 (don't know model). Seemed high to me. Another local dealer sells BH. He qouted $2700 for installation with pick-up/delivery. This is for either the M146 or 1846QT, I'm not sure yet. My questions are: Is the quality good on the BH FEL's? Are these two FEL's removable? I have read about quick attach systems, but if this is the only front end impliment I will be using, do I need it? I want to remove the FEL when mowing. I guess I just need someone to explain removing/attaching a FEL and the difference between having a quick attach system or not. I have done searches and read for a couple hours, but really can't find the info I'm looking for. Thanx in advance for any help.
NH TC18
-Dave
/ FEL questions #2
TC18inNY,
I hope I can keep this simple without babling. I tend to do that. I believe both loaders will give you the quick removal system. Usually takes about 5 minutes and you can have the complete loader removed except the mounting brackets. You can take it one step further and get the quick attach which will usually end up costing you a lot more. The quick attach allows you to basically take the bucket off and put other implements on your loader in a quick and conveinient way.
You have already told us you wanted to take the loader off for mowing pretty much everyone does. You don't need that weight up there to reck your lawn. But you still have to decide if you need the quick attach system. What other things will you be using your loader for other than the bucket. If you are not using it for anything else then the quick attach is a waste of your money. There is multiple companies out there that follow under your quick attach accessories and may more people here can chime in. But definately you want the loader that you can remove. Also check with New Holland as to what price you can get for their loader. I am kind of partial to staying with like brand equipment for things like loaders. Othes will say different.
Hope this helps you,
murph
/ FEL questions
I agree with thrci that you should check out price of NH loader. I have the new 12LA with my TC18, and I'm pretty sure it has better specs than the BH. One figure I saw for the M146 was 825# lift at the pivot pin; 12LA is 1090 at the same location. However, the 12LA may not fit if your TC18 is older - check with the dealer. I would expect it to be somewhere in the $3500 range, which would compare with the Woods loader.
/ FEL questions #4
I could just about write a book on this subject right now, but I'll leave that to Muhammad! I just went through the same thing you're going through. In summary, my advice is to get the factory New Holland loader if you can get a decent price on one! You should also be sure and kick yourself once a week for not getting the loader when you bought the tractor, because you're going to pay more now. I bought a Bush Hog M246 and regret it. That being said, the M146 might be OK. There is information on their loaders on their web site, www.bushhog.com. The Woods 1012 might be OK, but probably too big for a TC18, so consider the 1006, 1008, or 1009. There is a .pdf file on the Woods loaders on their web site, www.woodsonline.com. The main thing you need to do is to do what I didn't do, and that is to actually see the loader installed on a tractor like yours (same exact model) and then decide if you like it or not. Find out how much the loader itself weighs, how much weight is left on the tractor when the loader is detached, and how much weight you'll need for ballast. Find out if any mounting brackets get in the way of engine maintenance, even when the loader is detached. Find out if any mounting brackets go under the tractor to the drawbar and find out if they get in the way of a mid mount mower (if that matters to you) or reduce your ground clearance.
I think any loader they make these days is detachable from the tractor, but double check that. I can tell you that the Woods 1012 and the Bush Hog M146 are both detachable very easily and it only takes 5-10 minutes. If you get quick attach bucket option, make sure it's the Skid Steer compatible type, or you'll be limited on what attachments will fit it. The quick attach bucket option will add some weight to the front of the loader. I know that the Bush Hog M146 does not come with the quick attach bucket option.
You might want to read these posts:
FEL options for my Boomer
Ordered my Bush Hog M246 FEL
When is rear ballast needed with a FEL?
/ FEL questions #5
TC18,
I would also agree with the above comments. I'm a kubota man and my dealer made his point VERY clear about staying with like brands. First, they engineer them for their tractors. Second, if there's a warrentee issue then there might be an issue with having un-like brands attached. If you decide on BH or Woods I would check out Saxby Implements in Mendon. They are a family business and have given me exceptional service. Best prices around in my opinion.
Doug
/ FEL questions #6
</font><font color="blue" class="small">( my dealer made his point VERY clear about staying with like brands.
Doug)</font>
That's true with all dealers, but at the same time that they say that they drive people away by overpricing their factory loaders if you don't buy the loader with the tractor. I even had one dealer ask me if I had bought the tractor in the last year or not because it would be $100 less if I had. Why should that make a difference? I can see paying a little more to cover the extra shipping and other handling fees or whatever, but there's no reason other than greed for a loader to cost over $1000 more because I didn't buy it when I bought the tractor! I case you can't tell, I'm starting to get steamed about this whole thing!
/ FEL questions #7
</font><font color="blue" class="small">( I case you can't tell, I'm starting to get steamed about this whole thing! )</font>
Danny, I have two jobs to do next week down your way. I'll be in Indy Sunday through Tuesday and then I'll be heading down to Lebanon Kentucky. If I had time, and it was at a decent time of day, I was going to see if we could get together on Tuesday Or Wednesday. Maybe I should wait until you get your loader situation figured out?
/ FEL questions #8
Spencer - That would probably work out good. Maybe if you had time you could come and see this loader for yourself and see if I have valid complaints, since you can compare it to your 7308. When you go to KY it would be right on your way. Let me know what you feel like doing. Even if you don't have time to come to my house, let me know when would be a good time to meet somewhere right off the highway in the Columbus area. There are a bunch of restaurants at Exit 68. Do you still have my phone number and the directions?
/ FEL questions #9
Danny, Hopefully we will be able to work something out. I just got an email with an updated job schedule. Now it looks like I will be going from Indy to Fairfield Iowa and then on to Lebanon Kentucky. If it looks like I will have some time I will give you a call and give you as much notice as possible.
/ FEL questions #10
Spencer - OK, just sent me a PM message when you find out more.
/ FEL questions
Here's the deal. My TC18 is the "older" style from what I am told, so the NH 12LA won't fit. The Woods is too much money. The Bush Hog I have been qouted on is the 1846QT which the dealer says has the quick remove feature. I won't be using the loader for anything but the bucket. I will call Saxby tomorrow for pricing, didn't even think of them. Ohh yeah, I didn't buy the tractor new, so buying a loader at time of purchase (6 days ago) was not an option. Thank you for all the help. I'll let you know what I go with and how I like it. Anyone have this tractor/loader (TC18/1846QT) setup? How do you like it?
-Dave
/ FEL questions #12
TC18inNY:
I don't have a TC18, but I had a BH 1846QT loader on my first tractor, a Ford 1700. I was generally pleased with the loader. The steel in the lift arms was lighter/thinner than the steel in the 7108 loader I have on my present tractor, but it seemed strong enough. I never noticed any flex in the lift arms. I only had two small problems with the loader.
The first was when I wanted to make minute adjustments (raise the loaded bucket just a little bit), the loader would first drop slightly, then raise when I added more joystick. Turned out to be a damaged O-ring in one of the arm cylinders -- apparently damaged during assembly. Took a while to figure out what was causing the problem, but when they figured it out, the dealer covered it under the loader warranty.
The second problem was the Ag tires on the front end would rub or hook on the mounting bracket if the wheel was turned sharply and I happened to go over a bump or through a dip, so the front axle "rocked" a little. Was not a big problem, but slightly irritating. I don't think I would have had the problem with Industrial or Turf tires.
All in all, I would have no problem adding this loader to another tractor in the 15-25 Hp class.
One last thought: If you use a MMM, you may want to be sure that the loader mounts are compatible with the MMM, or you may have to remove the FEL whenever you use the MMM, which may or may not bother you. /forums/images/graemlins/crazy.gif
Oops - Just went back and read your original post. Yes, the 1846QT was "quick attach" -- remove a couple of bolts and the "legs" for standing it up while detached are held on by pins during normal operation -- pull the pins, insert the legs in the proper place and use the pins to hold the legs in place.
P.S.: You can order the loader in <font color="blue"> Boomer Blue </font> . /forums/images/graemlins/smirk.gif
/ FEL questions
There is quick attach, as in the loader to the tractor. I think most all new loaders are like this.
Then there is quick attach, as in the various buckets to the loader itself. I think there are a couple of different incompatable designs of this, with perhaps the 'Bobcat' style being most common?
I think I'm getting lost on who is talking about which quick-attach: - loader removal, or bucket exchange. /forums/images/graemlins/smile.gif I hope the person asking the question in the first place can see the differences.
--->Paul
/ FEL questions
Yeah, I understand the difference between the two. I just came from a dealer about 4 miles down the road that sells Kioti. He was just a nice as pie. I called earlier in the day and he called around all day getting prices, checking compatibility with tractor, etc. He ended up giving me what seems like a good price and he ordered it today. He said should be coming within 2 weeks. He will pick up/deliver tractor. What a difference dealing with this guy then some of the other dealers I have talked to. He just made me feel good about the whole experience. I'll just have to wait to see if he pulls through. By the way, I'm going with the BH M1846QT. Thanx for all the help.
-Dave
/ FEL questions #15
Dave - Good luck! As near as I can tell, you didn't actually see the loader installed on a tractor like yours, so you're taking a chance like I did. I hope you don't regret it like I did! I really don't think you'll run into the weight problem that I have though. The question is whether or not the mounting brackets will be in the way of things. For sure, it will be strong and will work very smooth.
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
Deere 672GP (A64126)
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
Unverferth Assist Wheels (A64127)
Unverferth Assist...
