FEL question
/ FEL question #1
double hunter
Ford 1715
Just bought a 3650 with a Bushhog brand loader, the joy stick does not return to the neutral position when you let t go, there is a spring located on the bottom with a nut beneath, is there any type adj to correct this, thanks In advance
/ FEL question #2
Likely just needs lube. Some type of spray stuff works great!
/ FEL question #3
Perhaps it just needs lubricated? I've had backhoe joysticks stick because pins in the joints had gotten a little rusty. Try your favorite penetrating oil (PB-Blaster, Liquid Wrench, WD-40).
/ FEL question
Tried lubing, did not work, joy stick still not going back to neutral pos.
/ FEL question #5
It's a older tractor, might need to be used, get the lube worked into all the joints.
/ FEL question #6
There are centering springs under the bottom cap which return the spool to center.
Remove the cap and inspect, clean, tighten nuts, lube good and make sure the water hole is positioned so any water can drip out. There may be little balls and springs, so be careful if taking it completely apart
If the valve is cable operated, check for full movement.
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
generator trailer (A61569)
generator trailer...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
