FEL question
/ FEL question #1
double hunter
Ford 1715
Just bought a 3650 with a Bushhog brand loader, the joy stick does not return to the neutral position when you let t go, there is a spring located on the bottom with a nut beneath, is there any type adj to correct this, thanks In advance
/ FEL question #2
Likely just needs lube. Some type of spray stuff works great!
/ FEL question #3
Perhaps it just needs lubricated? I've had backhoe joysticks stick because pins in the joints had gotten a little rusty. Try your favorite penetrating oil (PB-Blaster, Liquid Wrench, WD-40).
/ FEL question
Tried lubing, did not work, joy stick still not going back to neutral pos.
/ FEL question #5
It's a older tractor, might need to be used, get the lube worked into all the joints.
/ FEL question #6
There are centering springs under the bottom cap which return the spool to center.
Remove the cap and inspect, clean, tighten nuts, lube good and make sure the water hole is positioned so any water can drip out. There may be little balls and springs, so be careful if taking it completely apart
If the valve is cable operated, check for full movement.
JOHN DEERE 7330 PREMIUM TRACTOR (A62130)
JOHN DEERE 7330...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
