Front-End Loader FEL Published Ratings
/ FEL Published Ratings #1
Mike058
Key Peninsula, Wa
Kioti CK3510SE
When a manufacturer rates a front end loader at X pounds, does that mean you can lift X pounds with the standard bucket, or do you have to subtract the weight of the bucket from X?
I assume the first. Replace the OEM bucket with a grapple (for instance)that weighs less, and you can lift more than they say-add a heavier after market bucket and you lift less than the rated load.
But you know what they say when you assume something.
LandHonor Anchor Shackles (A62183)
LandHonor Anchor...
LandHonor Auger W/2 Bits (A62183)
LandHonor Auger...
2016 PETERBILT 579 (A63569)
2016 PETERBILT 579...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2006 Chevrolet 1500 (A62180)
2006 Chevrolet...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
