FEL problem with dump
   / FEL problem with dump #11
You may check your bucket leveling rod that indicates your bucket position it may have been bent
   / FEL problem with dump #12
The "fast dump" is an anti-cavitation circuit built into the valve spool. When you move the lever part way to right oil from the rod end free flows back to tank, and weight of the bucket load can pull the cylinder out faster than gear pump can fill the base end leaving an air pocket in the base of the cylinder. This is more noticeable when running at lower RPM. When you move the lever fully to the right this opens another circuit in the valve that sends the oil from the rod end back to the base end along with the gear pump supply, which keeps the cylinder purged and moves a little faster.
Good point, I will check this tonight.
Thanks. I'll try to see if it happens at a higher RPM.
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
