FEL Pressure ?
   / FEL Pressure ? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
I know I'm really asking for trouble from the safety-patrol but I will pose this question anyway. Before I bought my tractor, I was shopping at another NH dealer and I commented that the FEL did'nt have enough downforce to lift the front end of the tractor without rolling the bucket. The John Deere and Kubota's do this easily. Well, he sent the tractor into the service bay and it came out five minutes later with enough downforce to do what I asked.
OK, where is the relief that they adjusted ?
   / FEL Pressure ? #2
<font color=blue>"Well, he sent the tractor into the service bay and it came out five minutes later with enough downforce to do what I asked."</font color=blue>
Aw geesh, now we gotta worry about tractor steroids too?/w3tcompact/icons/eyes.gif
   / FEL Pressure ? #4
<font color=blue>...OK, where is the relief that they adjusted ?...</font color=blue>
Ok Jerry... you're asking for some Top Secret... information... /w3tcompact/icons/wink.gif
You better "post" your security clearance and credentials before that issue can be addressed... /w3tcompact/icons/tongue.gif
Also New Holland has this 67 page form you must fill out to be reviewed and determined if you really need that information.../w3tcompact/icons/eyes.gif
   / FEL Pressure ? #5
Sounds like need to know only info. And I needs to know.
   / FEL Pressure ?
/w3tcompact/icons/hmm.gif Information provided so far is kinda thin. /w3tcompact/icons/eyes.gif
Someone will talk. I have my ways. /w3tcompact/icons/shocked.gif
   / FEL Pressure ? #7
On my TC45D w/ R4's the FEL does not go low enough to lift the front tires. You are simply at the end of the stroke on the lift cylinders. You can lift the front by dumping the bucket but the tractor needs to be in neutral. Otherwise you are fighting the HST as lifting the front pulls the rear tires forward.
I would strongly advise against messing with the relief unless you like changing hydraulic hoses.
JT
   / FEL Pressure ?
JT, I know what you are talking about when say that there is not enough travel left in the cylinders. Tipping the bucket into dump position can and will lift my tractor. But if you dump the bucket first and then try to lift with downforce, there is not enough pressure. In this scenario it's not a matter of cylinder travel. All the John Deeres and Kubotas that I test drove could do this easily.
To be clear, I am looking to tap a little more of the hydraulic power for lifting stuff. My tractor is rated at 2150 psi, but the loader goes into relief at 1800 psi. I know that it is set this way for a reason. But, theres got to be room for a 'little' increase.
   / FEL Pressure ? #9
You might also notice a difference when the tractor is warm to when it is cold. When my TC35 is warm it will pop the wheels off the ground in a blink of an eye, when cold it is very sluggish. I guess the cold hydro fluid flows more slowly and pops the relief valve earlier.
Peter
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
JCB 8029 CTS EXCAVATOR (A52709)
JCB 8029 CTS...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2019 Ford F250 (A55973)
2019 Ford F250...
1995 TALBERT 50 TON LOWBOY TRAILER (A58214)
1995 TALBERT 50...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
