Dirt Moving FEL on GC2400 for Digging?
   / FEL on GC2400 for Digging? #11
Practice, practice, practice.....
   / FEL on GC2400 for Digging? #12
Just some of the digging I have done with my FEL on my 2310.
Doug
   / FEL on GC2400 for Digging? #14
You can dig a well with a teaspoon too. :laughing:
   / FEL on GC2400 for Digging? #15
The BH was for the septic tank,(yes it was able to go deep enough for a 1500 gal. concrete tank with a few tricks) leach lines, earth tubes and drainage lines. The big hole for the basement, driveway and pad leveling was all FEL.
Doug
By the way the the dirt pile from the hole is the picture to the left that the tractor is setting on.
   / FEL on GC2400 for Digging? #16
Save | HERE's how I do it.
Hi, folks,
Not sure if I should place this here or in "buying/pricing" but here goes. Can the FEL that goes with the GC2400 be used for digging? For instance, if I wanted to scrape away topsoil down to a depth of 6 to 12 inches for a path, or just for grading? If so, does anyone have experience comparing it to the Kubota 2320 with the LA304 FEL?
Thanks,
Joe
   / FEL on GC2400 for Digging? #18
Hi, folks,
Thanks,
Joe
I scraped the sod from my garden area, using just the FEL. I also used it to dig up stumps.........so I would say Yes.........it can be done from my experiences.
But with that said, I would consider getting a toothbar, for on the FEL............probably make a world of difference.
I have no experience with the Kubota 2320, but it sounds like an apple-to-oranges comparison.
   / FEL on GC2400 for Digging? #19
I was able to remove 4-5 inches of sod and dirt with some rocks in it when I leveled out the area for my new concrete pad. Worked great. I was impressed. The backhoe is a must for extra weight and good traction.
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
TRAILER AXLE (A51244)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
7615 (A47384)
7615 (A47384)
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
