Dirt Moving FEL on GC2400 for Digging?
   / FEL on GC2400 for Digging? #1
jmpbuffalo
Western New York
Massey Ferguson GC 2400
Hi, folks,
Not sure if I should place this here or in "buying/pricing" but here goes. Can the FEL that goes with the GC2400 be used for digging? For instance, if I wanted to scrape away topsoil down to a depth of 6 to 12 inches for a path, or just for grading? If so, does anyone have experience comparing it to the Kubota 2320 with the LA304 FEL?
Thanks,
Joe
   / FEL on GC2400 for Digging? #2
No way is a little 2400 is not going to be effective, digging with the FEL.
Loosen it up with a plow first, and then you will have no trouble removing it with the 2400 FEL.
   / FEL on GC2400 for Digging? #3
Although its not the proper tool/attachment for the job, it can be done.It will take more time an patience. a toothbar will also make it easier to do.
   / FEL on GC2400 for Digging? #4
it's very easy to underestimate those machines.:)
   / FEL on GC2400 for Digging? #5
I don't think the Kubota is going to do much different. You must loosen the soil first to remove it first.
   / FEL on GC2400 for Digging? #6
Short video and pic of what these small tractors are capable of.
85% of this was done ,using the loader.
YouTube - GC 2310
   / FEL on GC2400 for Digging? #7
You can do a lot of dirt work if equipped for the task the other end of the little Massey would need a box blade with rippers to loosen the soil and I would get a tooth bar. You can dig with a FEL but it is better to loosen it up a bit before scooping it up. I also do most of my earth work in the spring when the freeze thaw cycle has softened the ground for me.
   / FEL on GC2400 for Digging? #8
Depends on the type of soil you have. With light sandy soil it's easy. With heavier clay soil I'd break it up first. If rocky I wouldn't try it with a SCUT. IMHO
   / FEL on GC2400 for Digging? #9
All true.:thumbsup:
Thanks for all the replies. The video showed just the sort of thing I had in mind.
Joe
TARTER INDUSTRIES 7' ROTARY TILLER (A51243)
TARTER INDUSTRIES...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
2 pt IH Sickle Bar Mower (A50515)
2 pt IH Sickle Bar...
91013 (A48082)
91013 (A48082)
2019 PRINOTH PANTHER T14R CRAWLER (A51242)
2019 PRINOTH...
