FEL Mods
   / FEL Mods #11
<font color="blue">some plow cutting edges...1/2'' thick by 6'' wide. I am going to bolt that to the top of my New Holland bucket...Should stiffen it </font>
You betcha! Not only that...you'll be ready to scrape snow from any ceiling your tractor can get to. /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
OkieG
   / FEL Mods #12
I put a piece of 3/8" x 2 1/2" x 48" flat iron on top of the bucket.
Then a 1/2" diameter "D" ring and plate was welded close to the outside edge of the bucket on each side.
In the center I put a 5/8" slip hook.
I used the D rings because they're much stronger (IMHO) than hooks. Also they can be "flopped" over to bring a chain up the back side of the bucket. (That's how a lot of add-ons fasten to the bucket.)
GrayBeard
   / FEL Mods #13
If you want real strength weld a piece of 2-1/2"x2-1/2"x 1/4 hollow square tube on top of your bucket. then weld the hooks or whatever to that. with the hollow tube you can always slide a crowbar in there. Weld the tube about every 8-10 inches for at least 4".
   / FEL Mods
What do you use the crowbar for???
Has anyone installed a tooth bar on their FEL? Do they work (rugged enough) and are they easy to remove?
   / FEL Mods #15
Peeps do it all the time. Yes they work good.
All kinds of uses for a crowbar or a digging bar. Moving implements, logs, cleaning stuck dirt out of the bucket, good for throwing when your mad /forums/images/graemlins/tongue.gif etc..
   / FEL Mods #16
</font><font color="blue" class="small">( Has anyone installed a tooth bar on their FEL? Do they work (rugged enough) and are they easy to remove? )</font>
Are you kidding? /forums/images/graemlins/laugh.gif If you do a search for "toothbar" I'll bet you find more than you want to read. But if you're not kidding, the answer to all three questions is "Yes". If you have any digging to do with your front end loader at all and you get a toothbar, you'll never want to be without one in the future.
   / FEL Mods
Sorry:( but can't say that I was kidding. First tractor and frustrated by digging w/ a smooth blade. Borrowed my friends Bobcat and what a diffierence. I know my 4500 is not built like a Bobcat but I figured the teeth would help.
Just want to make sure they remove easily for other work.
   / FEL Mods #18
After I bent the top edge of my 460 FEL bucket, I got a 3" diameter 1/4" wall thickness pipe from the scrap yard. I drilled and tapped 3/8" holes on 4" centers and used grade 8 bolts to bolt it to the bucket and do the final straighening of the edge then I welded it along the edge of the bucket and welded on a couple of chain hooks. I have since bent the tooth bar and the top mounting brackets on the bucket but the top edge of the bucket is straight as an arrow. The whole loader assembly is loose and it and the bucket rattle around on the mountings but that edge will outlast the loader by far since it is the beefiest part of the whole loader.
   / FEL Mods #19
</font><font color="blue" class="small">( Just want to make sure they remove easily for other work. )</font>
You have to drill two holes in your bucket to mount the toothbar with two bolts, and if the toothbar is the proper length, then all you have to do is remove those two bolts to set it off when you want to.
   / FEL Mods #20
Maybe where you live its not called a crowbar. some might call it a pry bar. Mostly used around here to make a small hole in the earth to start a fence post into. we use them for many things around here.
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
Krause Dominator 4850-18ft (A57024)
Krause Dominator...
Horse Weathervane (A55853)
Horse Weathervane...
Elgin Pelican Street Sweeper (A55851)
Elgin Pelican...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 CuYd Refuse Garbage Truck (A55852)
2007 Freightliner...
