FEL lubrication - has to be a better way
   / FEL lubrication - has to be a better way #31
I have the Lock and Lube but noticed Harbor Freight is carrying their own now.
   / FEL lubrication - has to be a better way #32
   / FEL lubrication - has to be a better way #33
The biggest reason I got electric was getting the manual gun primed after changing out the tube. Is sure beating pumping grease though.
   / FEL lubrication - has to be a better way #34
Real men use an ARO air greaser with a 50 foot grease hose and and a double joint pistol grip gun. Babies use battery powered grease guns. Guess real men have thicker wallets too.
ARO makes GREAT stuff!
   / FEL lubrication - has to be a better way #35
I have one fitting that won't accept grease. How does that rejuvinator thing work?
I have one!
Could not get it to work on the one fitting I tried, but fitting is in a difficult location to hit.
   / FEL lubrication - has to be a better way #36
Sometimes you gotta replace the zerk fitting itself. Make sure you get the right size
   / FEL lubrication - has to be a better way #38
Has anybody mentioned a lock and lube yet? :) It is one of those few "gizmo" inventions that is better than advertised.
On FEL's if the fitting won't take grease, sometimes if you just change positions on how the joint is setting it will free it up (raise or lower the FEL or curl the bucket). If that doesn't work, what you do is loosen whatever holds the pin you are trying to lube in place and beat the pin back and forth a bit with a hammer. That will usually allow it to take grease.
   / FEL lubrication - has to be a better way #39
Working on older farm equipment, I have used it a lot. Patience and diesel fuel or any penetrant. Basically a steel syringe that you tap the plunger with a hammer and instead of a needle it has a zerk fitting. Sometimes even changing the zerk won't work cuz of the hard grease in the joint. This injects it in easier than grease and THEN it will take grease.
   / FEL lubrication - has to be a better way #40
Several, several times :)
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A55788)
2008 Ford E-350...
Peacock Statue (A53316)
Peacock Statue...
2018 BOBCAT T450 SKID STEER (A52706)
2018 BOBCAT T450...
2023 54ft Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54ft Hooklift...
Fast 9613N (A53314)
Fast 9613N (A53314)
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
