FEL Lift Capacity For Unloading Semi Trailer
   / FEL Lift Capacity For Unloading Semi Trailer #1
rebelback
South Arkansas
2010 Case Farmall 45 HST
I have a 2010 Case Farmall 45 tractor with an L350 loader. The loader's listed lift capacity on tractordata.com is 2,000 (full at pin). I have 26 pallets of wood shavings being delivered next week and am intending on using my tractor to unload them. The manufacturer has stated that a loader with a lift capacity of 2,000lbs at 4' should be used.
My pallet forks weigh roughly 340lbs. I plan to have my box blade attached to the rear. It weights 679lbs per manufacturer specs. My rear tires are also filled with water which should add another 392 lbs per tire of weight to the rear if internet math is correct. So, I should have roughly 1,463lbs of counter weight to the rear of the tractor.
Should I have any problem lifting these pallets off and out of the rear of a semi trailer? I feel like I've lifted logs this heavy before with my grapple, but I've never actually weighed any of them.
   / FEL Lift Capacity For Unloading Semi Trailer #2
It should be capable of that task. Just be sure you don't have to back uphill from the semi-trailer and keep the load as close as possible to the ground just as soon as the load clears the trailer.
   / FEL Lift Capacity For Unloading Semi Trailer #4
Mine has ~1850lbs lift at the pins.. With forks, I could *barely* lift ~900lb pallets of shingles off the flatbed delivery truck, about 48" deck height. They were originally loaded to ~1250lbs, but we had to remove bundles since the loader couldn't move.. at all.
You should cut your expected lift capacity about in half when lifting with forks.
I did a quick test tonight and was only able to lift 1400lbs of feed 3' off the ground. I'm going to do a pressure test to see if I'm within specs on my hydraulics, but either way a ton at 4' isn't happening. At least not with pallet forks.
   / FEL Lift Capacity For Unloading Semi Trailer #6
The manufacturer recommendation probably has a safety factor built in. How heavy are the pallets?
Doug in SW IA
   / FEL Lift Capacity For Unloading Semi Trailer #7
Sounds like this isn't going to work, based on specs, and based on your experiment.
I think the first thing to go wrong will be when you first try lifting the pallet. Your system will go into relief instead.
But, this seems like a safe thing to try, maybe if the numbers get somewhat better (partial unloading each pallet, or getting a heavier machine, or whatever). Worst case would be tipping forward before you get the load close to the ground, but you can kind of plan for preventing that, like the stuff RayIN suggested.
   / FEL Lift Capacity For Unloading Semi Trailer #8
Can someone explain how the math works? I'm sure I'll be in this situation soon enough. (or link to it) Thinking of a flail mower, 600# shipped weight.
My tractor is capable to lift 1900# at pin height of 60"
Using clamp on forks, how can I determine how much weight the tractor can lift at this height? Forks rated for 2000#
   / FEL Lift Capacity For Unloading Semi Trailer #9
Whatever you do, lift or not, be sure to lower the load close to the ground as soon as you can. I had that issue a while ago with full pallets of quick crete (2500 pounds) and while I was able to lift them to get them to slide on the trailer deck, once clear of the deck, I quickly dropped them to grade height. Conversely, you want to get your forks as far under as you possible can and it you cannot dead lift the, use your curl (rollback) to help out.
3 days ago, I offloaded a full 350 gallon tote of DEF and the tare weight on the tote was 2900 pounds, well beyond the lift capacity of my loader. I used the lift and curl method to get it off the truck and on the ground. Two things I did was first I made sure the pivot pins on the loader were wll greased as dry pins will drastically reduce your loader capacity and I used the front wheel assist to get it off the truck but immediately disengaged it because moving that much weight will play hell on the front axle if engaged. In fact, I rarely use front wheel assist except when loading large round bales.
   / FEL Lift Capacity For Unloading Semi Trailer #10
Measure the distance from the pin the loader arm pivots on (by the operator station) to the pins where the bucket or skid steer quick attach frame mounts on the loader frame. Call that distance A. Then measure from the loader arm pivot to the estimated center of gravity of the load on the forks. Call that B.
Your lift capacity of the load on the forks is:
published capacity at the pins * ( A / B ).
i.e. if A is 100 inches and B is 200 inches, the load capacity is cut in half. Don't forget to include the weight of the bucket and bolt on forks as part of the payload. Since their CGs are closer to the loader arm pivot than the CG of the actual load they reduce payload by a little less but it's close enough.
flooring (A55758)
flooring (A55758)
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
2119 (A58376)
2119 (A58376)
New/Unused Electric Golf Cart (A57453)
New/Unused...
Case-IH 586G (A57148)
2022 Chevrolet Tahoe SUV (A56859)
2022 Chevrolet...
