FEL Joystick
   / FEL Joystick #11
Just a thought but is it possible to just switch the hydraulic lines to get it to work the other way?
   / FEL Joystick
I tried that actually and it does work except you lose float
   / FEL Joystick
As the one guy mentioned though if the stick was vertical it actually would be proper as it were
   / FEL Joystick #14
The joystick lever is mounted correctly by ISO standards and we recommend that it not be modified in a way that would reverse things. Whether vertical or near horizontal, the lever is moved in the same directions for up or down movement regardless of who’s loader or tractor brand. Think of back towards you if vertical mount or down to the floor if horizontal as the same movement, which moves the loader arms and bucket up away from the ground. Push forward if vertical or horizontal and the loader arms will go down and move bucket down and forward. Back and down get same movement, forward and up get same movement.
   / FEL Joystick
Thanks to tractor guy. Another member said the same thing, and now that I can picture it vertical it makes sense to me. First real tractor, I'm learning.
   / FEL Joystick #16
Late response...
The controls are inverted, which is standard on most equipment.
Without seeing the colors of the hydraulic hook ups, you can merely switch raise and lower hoses on both ends of the DCV (handle), and have up as up, and down as down.
The float position would be useless however, as it would be working with the up function.
Szeiger already tried this, as I read above, but this will not harm the hydraulics, same flow, just change in direction.
   / FEL Joystick #17
If you rotate the hydraulic control block for the FEL forward (mine has slots cut in the mounting plate that allow some rotation) and bend the joystick up, it will make the controls more like a vertically mounted joy stick; aka other tractors. .
   / FEL Joystick
I thought of that too. But now that I understand how it lays out vertically I'm mastering it
   / FEL Joystick #19
...The float position would be useless however, as it would be working with the up function...
This is not true. The float would work just the same. All the float position does is connect the "up" and "down" functions so that the fluid can free flow. It's (more or less) as if the two ends of the lift cylinders are connected to each other so the pistons can move in and out without resistance. This would work just the same weather the up/down hoses were correct or reversed, since it's basically just connecting them to each other. The float position on the valve doesn't "work with" up or down. It's an independent position that happens to be on the same axis as the up and down functions. :thumbsup:
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
BIN PARTS, SWEEP AUGER & ELECTRIC MOTOR (A52708)
BIN PARTS, SWEEP...
2024 Ex Mark Lazer Z 60in. Zero Turn Commercial Mower (A55973)
2024 Ex Mark Lazer...
GRAM HOME 5 SHANK CHISEL PLOW (A52708)
GRAM HOME 5 SHANK...
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
