FEL issues
   / FEL issues #1
jeeping
kubota L275DT with a BF400 loader. 3Pt works fine, curl works fine, loader going up it slow but can lift 600lbs +/- nothing more.
hydro pump has a whistle type noise when running. Kinda loud. I had all the cylinders on the loader rebuilt few years ago. I then changed fluids and filter. I changed out the quick disconnect hose fittings. I pulled the joystick and relief valve apart and cleaned. Nothing changed.
I flipped the hoses around from curl to up and down. Seemed like the loader went up faster but when I went to come down it would only drop a few feet then start to go back up. I had to shut tractor off to drop all the way down. I pulled hoses apart and blew the out. Everything look good.
I then replaced the hydro pump and everything is nice and quite. Until i use the loader. lift up and curl up make a whining noise like is its starving. When 3pt hitch goes all the way up. The motor comes under a load, you can hear it.
I pulled the 3pt speed control apart and everything looks good.
   / FEL issues #2
Do you have your three point lever in the full up position? If so move it to lower a wee bit. You may have your hydraulics at the limit and going into bypass mode.
   / FEL issues #3
Like roadworthy states try lowering the three point some. If loader now works your 3 point feed needs adjusting. Both halves of quick disconnects can fail so just changing hose end may not solve the problem if it is a QD failure.
Is pump quiet when loader is not in use?
   / FEL issues
yes i tired it with the 3pt lever in all positions. I changed the quick disconnects complete both sides.
yes pump is quiet when loader isn't in use
is it possible a hose on the loader could internally clasped in use? I've seen it happen with fuel lines
I wonder if i'm air bound. Ive let it run for several hours in hopes the air would work its way out
   / FEL issues #5
Do you have capabilities of installing a pressure gauge in the pressure line to the loader valve? If yes watch the pressure while you raise and lower and or curl and dump. This will provide some insight on what pressure is doing. If getting close to relief pressure that could be the noise you are hearing.
When using the loader watch the hoses to see if both hoses stiffen and swell while trying to raise or just the one.
If both hoses stiffen then there is a restriction in the rod end line going to the valve or lesser possibility something in the valve tank line. If something in valve tank line you could possibly damage the valve if tank pressure gets to high.
   / FEL issues #6
Sounds like you have done a lot of work without anything fixing it. Maybe some more history and information would help. .
When did the problem with the loader start? Or did it ever work right? Is your L275DT one with the optional power steering, hydraulic remotes, mower hydraulics, or any other additions to the hydraulic system? If so how are those workiing?
In general, hydraulic pumps are very quiet. If the flow is restricted too much, you get very high pressure and will hear the overload valve as well as the pump. Hearing either one means shut her down and find the blockage before running it more.
Amazon sells hydraulic test gauge kits with "T" adapters to fit any common quick disconnect for around a hundred dollars. You would want one with 5000 psi capacity.
Insert the T fitting into any quick disconnect dydraulic line. It can stay there indefnitely. Check the pressure in that line when that line is operating vs not being used.
luck, rScotty
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT 6'5"-16 DRAWER, 4 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
Hose Reel (A53424)
Hose Reel (A53424)
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A54865)
2015 Freightliner...
