FEL: Is this typical or normal?
   / FEL: Is this typical or normal? #1
GlueGuy
Veteran Member
San Francisco Bay Area California (CA)
Kubota B7500
I've got a little over 10 hours on the new 'bota, and I noticed that the little O-rings that are on the actuators for the four hydraulic cylinders for the FEL all stay out at the end of the shiny part of the actuators.
I've pushed them back into the groove around the working end of the hydraulic cylinders, but they won't stay.
This doesn't seem right to me. I would "think" that they are there to keep dirt from getting inside or wearing the outside of the actuator, or the inside of the cylinders.
So I think this may be a warrantee issue? Or do I need to be more agressive in pushing them back in? Any special tool to do this?
The GlueGuy
   / FEL: Is this typical or normal? #2
GlueGuy, our cylinders may be made differently. I don't know how you could have an o-ring coming out of the end of the cylinder, but I think I'm safe in saying they should stay in the cylinder; not move out with the rod. I'd ask my dealer about that.
Bird
   / FEL: Is this typical or normal? #3
I also have this situation on my new B21.
I'm seeing the dealer next week and will ask him.
   / FEL: Is this typical or normal? #4
That O-ring was used in assembly for painting purposes (to keep the paint out of the seal). It now serves no purpose on your tractor. You can remove them and cause no harm.
   / FEL: Is this typical or normal? #5
I guess that would explain why I hadn't seen one there; my dealer must have removed them before delivery./w3tcompact/icons/wink.gif
Bird
   / FEL: Is this typical or normal? #6
AAAAHHHHHHHHHHHHHHH!!!!
I just removed one of those O-rings and wow what an explosion! Hyrdaulic fluid everywhere!!!
Just kidding.....
   / FEL: Is this typical or normal? #8
Alan,
Your bio may have you as a "stiff" but I bet your sense of humour has gotten you into trouble more than once.
2014 Ram 1500 Pick Up (A47384)
2014 Ram 1500 Pick...
2001 Sterling Vac Truck (A50323)
2001 Sterling Vac...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
JUMBO COW HIDE (A51243)
JUMBO COW HIDE...
